Concentric slave quick release tool
Old 07-26-2007, 10:08 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
The manual calls for a special tool to release the hose from a concentric slave cylinder. Is there a generic way to get it off or is a dealership the only way to go?
Old 07-26-2007, 10:57 PM
fordman1090's Avatar
fordman1090
fordman1090 is offline
no you dont have to go to the dealer. If your replacing slave it will come with one. When i did mine i left it at home and have had to use either a flat head screw driver, or a fuel line quick release. Which ever one you can get to work better for you. you can probubly get the tool from an auto store for a few bucks.
Good luck
Old 08-17-2007, 08:28 PM
Gate-n-Rail's Avatar
Gate-n-Rail
Gate-n-Rail is offline
Is that only from the dealer, when the new line comes with the slave cyl?
Old 08-17-2007, 09:23 PM
fordfaninIL.'s Avatar
fordfaninIL.
fordfaninIL. is offline
You could use a small screwdriver, but I have messed up several as a result. They don't always release like they are suppose to. I bought the tool off of the Mac dealer. You can probably go to your local parts store and get one. It is a flat piece of steel with a slot in one end that fits over the quick connect sleave and allows you to push the sleave in and release it.
thedoctor
09-04-2009 09:36 PM
jbrown9709
09-18-2008 05:44 PM
greek4x4
New Member Introductions
11-23-2007 10:17 PM
1989F250
08-16-2004 05:10 AM
Quick Reply: Concentric slave quick release tool
