bleeding brakes
bleeding brakes
Curious,
I have the Supercrew 4x2, and just want to run some new fluid thru the brake system. With anti lock, is there any special procedure I need to be aware of other than the usual pump the peddle and add fluid as you drain?? I've bled and replaced components before, but not on a vehicle with antilock. Thanks anyone.
