Brake Fluid?
Old Apr 24, 2009 | 10:29 AM
canadianfordguy's Avatar
canadianfordguy
Brake Fluid?
What do you guys use for brakes fluid? I have been doing some towing on a trailer without brakes in the city and think i overheated the brake fluid.
Any recommendations?
Thanks once again FTE!
Old Apr 24, 2009 | 11:04 AM
Excursion4X4's Avatar
Excursion4X4
I just use DOT 3 fluid. Nothing special.
Old Apr 24, 2009 | 01:55 PM
ReAX's Avatar
ReAX
Ford makes a good Heavy Duty DOT3. I flushed mine with Performance Friction Z-rated because I had it sitting around. The boiling points are only about 20 degrees different, but either would be a great choice.
Old Apr 24, 2009 | 02:12 PM
aklim's Avatar
aklim
I use a DOT4 synthetic. I think it is made by Valvoline
Old Apr 24, 2009 | 02:18 PM
Stewart_H's Avatar
Stewart_H
Get a good DOT 3 rated fluid and flush your system with new fluid once a year, and you'll be fine.
Over time, brake fluid gets contaminated by water because brake fluid is hydroscopic, which means it absorbs water at every opportunity, so it must be changed regularly, just like your oil.
Since water degrades brake fluid by lowering the dry boiling point, it must be maintained like all your other fluids, unfortunately brake fluid is almost universally overlooked.
Stewart
Curtis Gruman
Oct 30, 2015 10:08 AM
sweet55
May 24, 2015 03:47 PM
Rusty_S
Feb 20, 2015 06:56 AM
kayladog1
Feb 28, 2007 04:57 PM
mullinsmn
Sep 1, 2006 12:39 AM
