Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
Alignment in Seattle area
Old 08-11-2007, 10:10 PM
johnve's Avatar
johnve
johnve is offline
I hope this is not out of line.
Can anyone give me a recommendation on a *good* alignment shop for my '83 F-250. I was told that only the toe was adjustable and that the I-beams would need to be bent to adjust caster and camber. Does that sound right.
Thanks!
John (Mountlake Terrace)
Old 08-11-2007, 10:11 PM
johnve's Avatar
johnve
johnve is offline
Wink No pun intended
I just noticed my first line.
Old 08-12-2007, 12:55 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Not too sure about specific shops over on that side, but Les Schwab and Goodyear are usually pretty good.
You truck still has kingpins, so yes it will need to have the beams bent to change camber. Before you have that done, though, make sure the springs aren't sagged, and that it has the correct rims on it. Because of the I beam design, having a different offset rim will change the amount of leverage the springs have, and will change the camber.
Old 08-12-2007, 09:37 AM
johnve's Avatar
johnve
johnve is offline
Thanks Jared, The height looks great. It's 2 wheel drive and sits nice and high. It has stock rims.
The Schwab in North City told me they could not do the bending.
I_Thnk_Ford
General Automotive Discussion
21
06-08-2015 11:07 PM
oldiron
1997-2006 Expedition & Navigator
05-29-2013 08:25 PM
NBC-Steve
12-25-2012 09:18 PM
cbzdel
1999 to 2016 Super Duty
13
06-20-2012 10:24 PM
richsoucie
03-03-2009 10:15 AM
Quick Reply: Alignment in Seattle area
