HFCM drain mod?
HFCM drain mod?
Is there a drain petcock mod or something with a handle on it that can be plugged into the HFCM?
I just bought a used '05 F350 and the hex screw drain plug on the HFCM looks worn - as if the previous owner used the wrong size allen wrench and augered it out. And I'm new to all this, but it sure looks like water/fuel will drain onto the frame rail and then "ride" the rail and spill all over the place instead of just into a drain cup.
It would seem like someone has come up with some sort of drain valve with a handle or petcock like on a radiator that makes draining the HFCM something that can be done by hand and would be cleaner (no rail, or down the arm, riding). Is there?
I just installed the IH drain plug this weekend and it is MUCH better than the stock one. Same Allen wrench to remove, but if for some reason rounded out, it can be removed by hand (if not too tight) or with pliers. It also will not fall completely out, so acts somewhat as a fluid director and creates much less spill. For $18 is a great little upgrade.
Originally Posted by Headrope
Exactly what I was looking for. Thanks, folks.
Any difference between the Ford or International part? Any reason I should use one over the other or is it the same part just in two different manufacturers' catalogs?
Hope this helps
The stock ford part and the IH part are different. The stock ford part, the head actually recesses back in slighltly, just about flush with the HFCM body. The only way to remove it is with the allen wrench. The IH part has a much larger head that sticks out about 3/4" from the body. It is knearled so you can remove it with fingers if not too tight, or with pliers. It also uses the same size allen wrench. When taken out, the IH unit will also remain in the whole where the stock ford unit comes clear out. Makes for much easier draining and it actually acts to direct the fluid as it is being drained.
Hope this helps
Cool. Thanks for the clarification. I sure don't know why they would have chosen to use the much smaller one for these trucks, what to same $2 per truck?? Well, I guess for a lot of guys that just drive and let others deal with the maintenance, it is OK. I sure like having things done right though. This drain plug is just a much better way to go.
Here is a pic . . .
