Look at the Crud in my HFCM...
Background...
2008 F-350 6.4 KR CC
I purchased 18 months ago with 72K
Immediately changed all fluids and filters.
When changing lower fuel filter in HFCM, noticed a bit of slime in there. Cleaned it out and put in new filter.
I drain the HFCM every month or so, and not much of anything ever comes out.
About a month ago the DRAIN WATER SEPERATOR light came on. Took off valve, cleaned it, and established nice flow. It completely drained and some water came out. All was good for 3 weeks, now DRAIN WATER SEPERATOR light comes on every day, then goes off after about 5 min.
Decided to take the HFCM apart. Look what I found...
It was like a layer of Jelly or wax with lots of dirt trapped in it. All cleaned out, filters changed and running like a dream now.
What would cause this to form? Any clues?
Leave well enough alone.
I have never touched mine, rather regular draining is all that is needed.
Glad I saw this...
How long is typical for the drain to be left open when draining the HFCM? I drained mine, of course only fuel came out, but I let it drain maybe 5 seconds...long enough to put about 1/16" in the bottom of a 20oz water bottle. The stream that came out was very small...kind of like what you would see at the end of your garden hose with the spicket only cracked open. I was figuring I would see a stream that would come out the size of the outlet nozzle.
The wild thing is.... If it wasn't making the sensor send a code, It really wasn't hurting anything there. It was a solid gel mass that really wasn't breaking apart. It was actually catching the larger pieces of dirt. It was way to thick and at the bottom of the pump in the bottom chamber. Could NEVER have gone to or through the filter.
My question is..... What made it? I only put Diesel Kleen in during the winter, besides that, just fill up once a week or so at a Shell station by my house..
tz
tz
What this is is Microbial Growth. This is common in diesel and jet fuel. It grows at the water/fuel interface and feeds on hydrocarbons. I have seen this in jet engine fuel controls and in my truck. If not attended to it will cause problems and eventually corrode parts. This is why I use Power Service Bio Kleen.
I think these should be taken apart & cleaned every 30k,
Regardless of # of filter changes. This crud WILL NOT DRAIN out - it stays stuck inside until opened up & Cleaned.
I agree with "If it ain't broke, Don't fix it" 99% of the time but this needs routine attention IMHO
chi6488
6.4L Power Stroke Diesel
09-27-2009 01:24 PM
