What metal are the radius arms made from?
I thought I read somewhere that they were cast steel. I'm pretty sure cast iron would be too brittle for that application. Regardless, I have found it very easy to weld them to steel for modification purposes. I use a MIG welder and steel wire with good weld penetration and strength.
J.B. Hebert
J.B. Hebert
I figured as much for the same reason. According to a nuclear welding instructor, cast steel requires pre-heating to 200-250 degrees and keeping it there during welding. It should then be allowed to cool very slowly (covered or buried in lime) to prevent stress cracking.
Thanks for the input...
I think they are actually forged steel. I say this because of the thick "flashing" remains on the top and bottom of the arm. Most of this flashing has been ground down at the factory, but it is still evident. If it were a casting, the flashing would be much thiner. Since it is an easy enough part to make with the forging process, and the strength required, forging would be the only way to go. Since forging produces similar grain structure to plate steel, welding should be no problem assuming the alloy is compatible.
ford390gashog
07-13-2004 12:13 PM
Mud_Hunter
05-13-2004 03:02 PM
Sorter
09-03-2001 08:36 PM
