Dana axle question
Dana axle question
Did the Dana 60, 70, or 80 ever come in a 5 lug pattern instead of the eight? Personally I'm not aware of a 5 lug D60 or higher. I guy says there is one under a 1978 parts truck he has. My guess is IF it does have a D60 that someone has swapped it in there and somehow converted it to a 5 lug pattern. What do you think?
I've never seen one, nor do I know of a manufacturer of hubs that will fit with a wide five pattern, But that don't mean anything. Anything is possible, but until you can climb under there and find the 60 raised on the webbing next to the carrier housing, I'd be willing to bet that it's a 9" under the rear.
Great topic for the drivetrain forum.
This should help as well.
http://77cj.littlekeylime.com/Dana60.htm
I have one in my 66 f100 check out this thread
https://www.ford-trucks.com/forums/6...n-an-f100.html
Well...I got the axle removed from the truck today. I swear to god it looks like a hybrid 9" and D60 together. It has the outter drums and all from a 9" but it has the center section of a D60 or higher. These are the only numbers I have been able to find so far.
on the bottom it reads: 70 7NAT OR 70 ZNAT and below that it reads 580
on the drivers side edge it reads: 23 ABC
I'll try to get some pictures of it within the next couple of days and post them. I want to know what kind of rear this is.
steves_F350_460
08-11-2010 02:38 PM
bronco1989
01-11-2008 07:06 PM
