Hydroboost on 73-79
Old May 25, 2007 | 11:40 PM
Fordguy545's Avatar
Fordguy545
Hydroboost on 73-79
Has anybody retrofitted their power brakes for hydroboost. Am considering it because I don't have enough vaccum to have decent brakes because my cam is so big. Truck is too heavy to not have good brakes. I figure that the hydroboost would solve all my problems and not screw up the look of the engine bay too bad.
Old May 26, 2007 | 12:23 AM
Torque1st's Avatar
Torque1st
Posting Legend
There are a number of threads on hydroboost here. Check them out!
Old May 26, 2007 | 02:38 AM
reignman's Avatar
reignman
I have installed a hydro boost system plus rear disc brakes. PM me if you want how I did it.
R
Old May 26, 2007 | 09:14 PM
f150_514ci's Avatar
f150_514ci
i have also done this swap and rear disc. i have a 76 f150 with adana 70 rear and 60 front 19'' of lift and 44's and let me tell you it doesnt take much pedal effort to stop it.
Old May 26, 2007 | 10:38 PM
Fordguy545's Avatar
Fordguy545
thats what I need because it didn't stop as good after putting the 20's on, and then swapped cams, and made the truck heavier, so it gets to be a handful when people pull out in front of you
Old May 28, 2007 | 11:17 PM
perkyford's Avatar
perkyford
Trailering
The one for a 94 and later superduty diesel is as close to a bolt on fit as you can get (very minor trimming to the firewall support and drill two new holes)and your master cylinder should bolt right on.
Jim
20powerstroke02
May 30, 2016 09:08 AM
timmytoes
Apr 15, 2016 09:41 PM
carguy29
Sep 30, 2015 04:05 AM
khadma
Offroad & 4x4
Feb 18, 2014 02:33 PM
okie72
Feb 15, 2014 09:35 PM
