4wd Shifter
4wd Shifter
yo,
To shift between 4H and 4L:
With auto hubs;
Stop the vehicle and place the automatic
transmission into NEUTRAL or depress the
clutch on manual transmission vehicles. Push the
transfer case shift **** down (toward the
ground) and at the same time pull or push the
lever straight forward or rearward (depending
on the desired position, 4H or 4L) in order to
shift the transfer case. This shift should be in
one continuous motion without pausing in the N
(neutral) position. Pausing in the neutral position
can result in gear clash and difficult shifting. If,
while shifting between 4H and 4L, the transfer
case gets stuck in the N (neutral) position or is
difficult to shift into either 4H or 4L, it may be
necessary to let the vehicle roll slightly and/or
turn off the engine (particularly on vehicles
equipped with automatic transmissions).
With auto hubs;
4wd Shifter
[font size="1" color="#FF0000"]LAST EDITED ON 09-Oct-01 AT 03:45 PM (EST)[/font][p]My 90' (automatic trans.) is the same way...4 high works fine, finally got it to go into 4low (since i never have needed to use it, it took a while to get it in 4low). It's just like the previous poster described it...
hail destroyer
10-20-2016 11:32 PM
Sdmusgrove0506
05-27-2015 12:09 PM
mmarmino
06-16-2011 04:35 PM
