351 Cleveland or Windsor
Originally Posted by krasmussen
I have a 1983 F-150. I am pretty sure that I have a Cleveland engine but everytime I go to order a part, the part dealer tells me that it must be a Windsor. Is there a relatively simple way to verify which engine I have?Thanks,
If the engine is original it isn't a 351C for one reason. NO F Series truck ever used a 351C. The 1977/82 F Series trucks were available with the 351M/400 engines. The 351W engine was first available in F Series trucks in 1980, and is still in use today.
Look at the 8th digit of your VIN, it's a letter in 1983. That is the digit that ID's the engine type/size. Only three V8's were used in 1983: 302 ~ F / 351W ~ G / 460 ~ L
The 8th digit in the VIN is a "G". And there are 6 bolts on the valve cover. It is starting to smell like a Windsor. Is there any reason to believe differently?
Originally Posted by 82F1507.5
Odds are it is a 351 5.8L Windsor engine for a variety of reason, but the six bolts suggest Windsor heads. I can't for the life of me think of a reason why someone would go to all the trouble to put Windsor heads on an older Cleveland block. So yes, odds are it is a Windsor.
also look at the exaust bolt if they're strait across itll be in the W family if one up ones down at a diaganal itll be the C,M family clevelands and M's used the same valve cover.the 351c used two bolts to mount the engine mounts to the block just like a W and they used a small block W style bellhousing.the M uses 3 bolts to hold the mount to the block and a bigblock style bellhousing.but like everyone else says 6 bolts it a windser. hey Bill if ya want i cant tell ya how C's and W's can swap heads
I'm not sure what you are trying to explain to me in the last sentence. My response was to the comment above me in my previous post
This was a popular swap back in the day when good Ford heads were hard to find, and modified heads were very expensive. Now they have aftermarket aluminum heads for the 302 and 351w, so it's not as cost effective to do the cleveland swap.
P.S. The Boss 302 had cleveland style heads on it from the factory.
Thanks for the other info.
RJL1
10-05-2016 01:09 PM
FireBlue
28
02-09-2010 10:09 PM
ExcellentRed
08-15-2003 11:01 AM
