1978 - 1996 Big Bronco
351 cleveland
Old Jun 9, 2001 | 05:27 PM
canadianfordman's Avatar
canadianfordman
351 cleveland
I am looking at a 78 Bronco and I think the engine is a 351 Windsor but something about looks wrong. The heads look a little bigger. My questions is how can i tell if its a windsor or a cleveland?
Thanks
CanadianFordman
Old Jun 9, 2001 | 07:22 PM
tratrex's Avatar
tratrex
351 cleveland
You probably have a 351 M. That is a very common motor for that year.
Old Jun 10, 2001 | 09:15 PM
canadianfordman
351 cleveland
Thanks, How do I tell what engine it is. I read all the stickers on the inside of the engine compartment and all it says is 5.8L.
Thanks again
C'Fordman
Old Jun 13, 2001 | 08:14 PM
tratrex's Avatar
tratrex
351 cleveland
Check on the valve cover, drivers side. should be a big sticker that says 351/400M 3 or 4 lines below it will give exact displacement ie; 5.8 = 351 along with spark gap and size, timing ect
Old Jun 13, 2001 | 08:52 PM
bronco1978's Avatar
bronco1978
351 cleveland
> The heads look a
>is how can i tell
>if its a windsor or
>a cleveland?
a sure-fire way to distinguish a 351C block from an M-block is the block
casting number, located on the right side of the block below the deck of the #3
and #4 cylinders, usually right above where the starter sits. All 351C blocks
have a casting number that starts w/ D0 or D2. M-block casting numbers start w/
D1, D3, D4, D5, D7, or D8. The D1 and D3 blocks were all built (originally) as
400s. The D5, D7, and D8 blocks were used for both 351Ms and 400s
And a M block from a W, by way of the dry or wet intake. A W will have the water neck on the intake, while a M will have it on the front of the block.
Old Jun 14, 2001 | 12:29 AM
canadianfordman
351 cleveland
Thanks guys
Old Jun 14, 2001 | 09:43 PM
kpoly's Avatar
kpoly
351 cleveland
Turbo Dog
29
Feb 20, 2017 02:46 PM
RJL1
Oct 5, 2016 01:09 PM
olblue77
May 31, 2016 04:43 AM
FireBlue
28
Feb 9, 2010 10:09 PM
krasmussen
Apr 9, 2007 09:38 AM
