56 272-3spd bellhousing part #?
The clean bell housing is from an original 1956 F-350, 272 CID with T98 four speed, casting #TBAB7505Z.
Ford part number: TBAB-7505-A = 1956 F100/350 272 3 M/T Heavy Duty / 1956 F100/600 272 T-98 4 speed.
The dirty bell housing is from a 1956 F100 with 272 and three speed, casting #TAAB7505A.
Ford part number: TAAB-7505-A = 1956 F100 272 3 M/T Light Duty & 3 M/T with Overdrive.
TBAB-7505-A was replaced in 1958 by B8Y-7505-A / TAAB-7505-A was replaced in 1958 by B8C-7505-A
Were on the right track...hooray! thanks for the pic's. Now a new question: Will the H/D F250 with the short and Narrow bolt pattern fit in a '1955 F100 pickup?
My guess is a yes.
Conclusion: later model tranny's which have the FORD PATTERN (short & Wide) should now fit where a older T85 tranny used to be. The length of the input shaft should be the same assuming you use a genuine Ford tranny.
Somewhat off topic: Did the T86 w/OD come with more then one bolt pattern. I'm seeing the early Tall & Narrow. Did this change to the Ford Pattern (short & Wide)?
Thanks Ron
My guess is a yes.
Thanks Ron
My guess is a yes.
Thanks Ron
My guess is a yes.
Thanks Ron
Bell housing for three speed:
Hole where the tranny main drive housing fits is 4 3/4"
Distance between top bolts 5 1/4".
Distance between lower bolts 6 1/4'
Distance between top and lower bolts 7 1/4"
Bell housing for the 4 speed:
5" hole where tranny main drive goes.
Distance between top bolts 8 1/2"
Distance between lower bolts 8 1/2"
Distance between bolts top to bottom 5 3/4"
HTH
Borg Warner T-85 3 speed manual with overdrive: 1942/48 Lincoln & Continental V-12 / 1949/51 Lincoln & Lincoln Cosmopolitan 337 Flathead V8.
Borg Warner T-85N 3 speed manual with overdrive: 1965/67 Galaxie/LTD 352 / 1965/71 F100 240/300 I-6; 352/360/390.
You mentioned these:
Just to be clear this "quoted group" as far as we can determine may have used the FORD PATTERN (Short & Wide)...true?
And, this includes the "FE" engine group as well as later in-line 6's. Is there a drawing or a picture of this tranny? Perhaps someone out there in Ford land...has evidence. I do see other car manufacturers using the T85. >>> Mercury, Packard,and Studebaker come to mine.
Were talking a "T85 3-speed w/ OD which features the short & wide bolt pattern"
Ron
Orange County
Ron
Orange County
Bill W
07-08-2011 12:15 AM
hmd_56
01-24-2010 08:11 PM
64fordf100292
08-19-2009 07:56 PM
pcmenten
15
01-07-2005 10:41 PM
