Hey I'm new to the forum and have read a lot of informative posts on this sight. My question is I have an 04 F250 PSD CC 4x2 Lariat that I am trying to find the factory code for the door keypad. I bought the truck used so of course the wallet card the owners manual talks about is missing. It is also supposed to be stamped on the PCM, but if I'm looking where I think the PCM is I can't see any codes without pulling the battery. Anyone have any ideas about how to find this code? Is the PCM mounted just outside the battery on the driver's side? Thanks for any help.
The PCM code is up behind the radio. If you take the center bottom dash panel off and look up with an inspection mirror you can spot the 5 digit factory code. Once you have that you can change it to whatever you want.
