factory keypad code
Old Feb 25, 2007 | 06:37 PM
drillmaster's Avatar
drillmaster
factory keypad code
Hey I'm new to the forum and have read a lot of informative posts on this sight. My question is I have an 04 F250 PSD CC 4x2 Lariat that I am trying to find the factory code for the door keypad. I bought the truck used so of course the wallet card the owners manual talks about is missing. It is also supposed to be stamped on the PCM, but if I'm looking where I think the PCM is I can't see any codes without pulling the battery. Anyone have any ideas about how to find this code? Is the PCM mounted just outside the battery on the driver's side? Thanks for any help.
Old Feb 25, 2007 | 06:48 PM
03 Power Smoke's Avatar
03 Power Smoke
Take it to a ford dealer and they can pull up the code in less than 10 min. I only charge $10.00 to pull lost door codes at my service department.
Old Feb 25, 2007 | 07:06 PM
conger's Avatar
conger
The PCM code is up behind the radio. If you take the center bottom dash panel off and look up with an inspection mirror you can spot the 5 digit factory code. Once you have that you can change it to whatever you want.
Old Feb 25, 2007 | 07:43 PM
drillmaster
Thanks for the info. I'll look behind the radio.
F2502011
Jun 26, 2017 10:42 PM
edlinfir24
Transit Connect
Dec 21, 2016 01:49 PM
RainDesert
Nov 7, 2016 12:10 PM
Will104
Mar 21, 2016 11:54 AM
3KIDDAD
Jan 17, 2007 09:13 PM
