Code question
First check the plug on the sensor for being fully seated. Remove it and re-plug it.
Located at/behind the crank pulley about the 7 o'clock position.
If the same code reappears after it is cleared, either test the sensor or replace it for the relitive low cost. It counts pulses from a toothed wheel as a way to tell the computer where the starting point is for all timed engine controls.
[QUOTE=tjlmml]I have a 2000 F-150 4.6. Code P0320 keeps popping up. I know what the code says in the book. Not sure what part I need to replace or even check for that matter... HELP please... Code meaning is...Ignition/Distributor Engine Speed Input Circuit Malfunction..b okay i will try to remove and clean out the wire plug in and maybe replace the crank sensor...do i have to unplug the battier when i reinstall the new crank sensor...:?
