Block heater cord
This is from the ford factory service manual. I couldn't find anything about which wire was ground and what not. Hope this helps a little.
Block Heater —7.3L Diesel Engine
<META content="Block Heater —7.3L Diesel Engine" name=tps_proctitle>Removal and Installation
- Drain the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding in this section.
- Raise and support the vehicle. For additional information, refer to Section 100-02 .
- Disconnect the electrical connector from the block heater.
- Remove the block heater from the oil cooler.
- To install, reverse the removal procedure.
The black and white wire go to the flat blades just be sure the green is the ground lug (round blade). Those are the colors used for 110V AC, not sure if the cord has the same colors.
You can use an ohm meter to find the ground wire. Place one probe on the battery ground and one on each of the 3 wires coming from the cord.
Restlesswildman
11-16-2014 07:09 PM
