Block heater cord
Old 02-05-2007, 01:05 PM
royallawnskc's Avatar
royallawnskc
royallawnskc is offline
Block heater cord
Recently the plug on my block heater cord ripped off while driving and just needed some help figuring out how to wire up a new plug to it. If anyone knows which is ground and what not it would be appreciated.
Old 02-05-2007, 03:02 PM
ponch37300's Avatar
ponch37300
ponch37300 is offline
This is from the ford factory service manual. I couldn't find anything about which wire was ground and what not. Hope this helps a little.
Block Heater —7.3L Diesel Engine
<META content="Block Heater —7.3L Diesel Engine" name=tps_proctitle>Removal and Installation
  1. Drain the cooling system. For additional information, refer to Cooling System Draining, Filling and Bleeding in this section.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Disconnect the electrical connector from the block heater.
    1. Remove the block heater from the oil cooler.
      1. To install, reverse the removal procedure.
      Old 02-05-2007, 03:04 PM
      ponch37300's Avatar
      ponch37300
      I can't seem to copy the pics over. Sorry
      Old 02-05-2007, 03:56 PM
      Cuda_jim's Avatar
      Cuda_jim
      Cuda_jim is offline
      The black and white wire go to the flat blades just be sure the green is the ground lug (round blade). Those are the colors used for 110V AC, not sure if the cord has the same colors.
      You can use an ohm meter to find the ground wire. Place one probe on the battery ground and one on each of the 3 wires coming from the cord.
      Old 02-05-2007, 03:57 PM
      Corner Gas's Avatar
      Corner Gas
      Corner Gas is offline
      Green is ground, which is attached to the center prong ( U shape) and the two other wires hook up to the outside posts, is doesn't matter which wire is hooked to which. I just had to do this yesterday myself. It is never warm when you have to do these jobs either.
      Old 02-05-2007, 05:13 PM
      Reckless's Avatar
      Reckless
      Reckless is offline
      For any plug truck or cord, neutral is the big/wide blade, hot is the smaller/narrow blade on any plug. I haven't seen the wires inside the covering on the truck, but typically for the wires: white is neutral, black/red hot, and green ground.
      Zss0894
      1999 to 2016 Super Duty
      02-05-2015 05:15 PM
      Restlesswildman
      11-16-2014 07:09 PM
      78f3504x4
      12-21-2008 02:21 PM
      MAKO314
      26
      01-18-2007 09:39 AM
      GoEIB1
      01-24-2005 05:43 PM
      Quick Reply: Block heater cord
