how to disable passenger window switch
Can anyone tell me a easy to disable the passenger window control? Being a 2 door supercab, I do not have the "window lockout" button on the drivers control. I would like to be able to control the passenger window only from the drivers side.
The problem is, my 2 dogs will put there paws on the passenger arm rest to look out the window. Occasionaly, they step on the window down button. Once he stepped on the window up button, while window was down and would have gotten his neck stuck in the window had I not pushed the driver control to stop the movement of the window.
Thanks!
Thanks!
I'm pretty sure that if you disconnect the switch that the window will not work at all. I havent done a newer vehicle so I'm not sure if that has changed. I used to probe the constant power wire to the particular switch and disconnect that wire from it. THis would allow the drivers control to operate the other windows.
dog issues
I have the same problem with my dog rolling up the window and the biggest problem I don't have control of the window just am able to stop it from rolling up anymore. And not having a window lock button if I leave her in the car with the air on she can roll down the window and as I'm in the store roll it back up on herself. Being a two door there only needs to be 1 set of controls. And I could almost use just one button with a little 3 way toggle switch like on the side mirrors. Most of the time it's either windows up or down. I sometimes will have one up and one down if there's a strong cross wind.
Buy a replacement switch off ebay or get one from the wreckers or something....disconnect switch on door...plug in replacement switch and leave hanging inside the door........voila.....window still works from drivers side....and passenger side armrest area still looks good, without a hole from just removing the window switch.
BTclassics
06-19-2017 10:48 PM
