Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 01-14-2007, 07:45 PM
amiller93's Avatar
amiller93 amiller93 is offline
Garage is empty, add now
amiller93 has a good reputation on FTE.amiller93 has a good reputation on FTE.
Boost Tube
http://www.puredieselpower.com/catal...esel-p-90.html
10 bucks I figured what the H i'll give her a try.
The install:
1. Open Beer and set on radiator
2. Unplug red line from waistgate canister
3. Plug boost tube into waistegate canister
3a. Pour beer on hand since you accidentally touched the turbo and had just shut her down (HOT)
4. Plug red line into boost tube
5. Finish 6 pack since hand is now hurting.
I could not believe the visible and SOTP results from this. Before at WOT i would see 17 psi getting on the interstate, now not quite at WOT i was seeing 22psi and I was up to speed 200-300 yards earlier than usual.
  #2 (permalink)
Old 01-14-2007, 07:52 PM
guzzle92's Avatar
guzzle92 guzzle92 is offline
no leaks here...
2002 Ford F-350
guzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to all
Alan, Keep track of you MPG and let us know how the tube affects it. I know when I tried to run with the wastegate disconnected, the MPG took a nosedive.
__________________
guzzle
02 F350 4x4 SRW EC LB Lariat
guzzle's Mods & Maintenance Website
If you own a 99-03 7.3 PSD, this is the place to be:
Roadside Help Network
  #3 (permalink)
Old 01-14-2007, 07:56 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
Are you sure it wasn't those beers making your truck faster?
__________________
7.3 fully built longblock for sale PM me
  #4 (permalink)
Old 01-14-2007, 07:59 PM
yellow401's Avatar
yellow401 yellow401 is offline
I MAY Retire When I Die..
yellow401 is starting off with a positive reputation.
Quote:
LOL! I'm wondering the same thing! That would be nice if it works, for those with wastegates.
__________________
-Jason
00 f250 CC SB 4"lift, 35's, Fabtech tracbars, Detroit Locker, DP Tuner6, MAC intake, 7" Stacks, Tru-Speed, Rotella ELC, Beans Van Turbo WW ATS, 6.0 Tranny cooler, BTS TRANNY, ITP/BTS Fuel Syst.
Waiting to Install: dusty parts boxes...
  #5 (permalink)
Old 01-14-2007, 08:02 PM
amiller93's Avatar
I just got back from filling up when I did it so I should be able to get some numbers next week. Only problem is the BTS VB and DP-Tuner go in next weekend so I can only get about 1/2 tank worth of mileage on the tube.
Over the last 3 months I have averaged 15.33mpg
Thats why i didnt disconnect the WG the way this works is it bleeds off about 1.5psi of the WG control pressure delaying the WG so I am hoping for a little less of the nosedive.
  #6 (permalink)
Old 01-14-2007, 08:06 PM
amiller93's Avatar
Na the beers were pain reliever on Saturday the testing was today.
  #7 (permalink)
Old 01-23-2007, 08:23 PM
amiller93's Avatar
Well Pocket here they are
for the 3 months prior to doing the boost tube I averaged 15.33
Keep in mind that half way though this tank the DP tuner and BTS VB arrived
Filled up today mileage over last tank was 14.19
Tommorrow the Tube comes off and well see what the dp tuner does by itsself.
  #8 (permalink)
Old 01-23-2007, 09:11 PM
bigtorque bigtorque is offline
bigtorque is starting off with a positive reputation.
ive had mine on for about 2 and a half months or so, and havent noticed any change in mileage, and there is no noticable power difference in low speed low rpm driving, but highway driving say 3rd and 4th gear after lock up, the boost tube made a huge difference, it pulls so hard at 60 to 70 mph @ 22 lbs of boost on stock tune where as before it really didnt pull, it just wound out.
__________________
03 F-250 7.3 PSD/CC/SB/4X4--
THANKS TO ---- RAGIN DIESEL - ITP DIESEL - HANSONS TRANSMISSIONS - AMSOIL PERFORMANCE PRODUCTS AND THE BEST IDEAS FROM GREAT FOLKS AT FTE.
  #9 (permalink)
Old 01-23-2007, 09:29 PM
amiller93's Avatar
It could be that 140 Smoke tune. Thats why I took it off so I can get some base tuner numbers and then see how it does. You are right though it sure does give it some nutz around 70.
  #10 (permalink)
Old 01-24-2007, 12:17 AM
bet 140 smoke is great on mileage
LOL
__________________
  #11 (permalink)
Old 05-02-2009, 07:55 PM
bigmack.81's Avatar
bigmack.81 bigmack.81 is offline
bigmack.81 is starting off with a positive reputation.
Could you post some pics of the tube? Wanna see if I can make it.
  #12 (permalink)
Old 05-02-2009, 08:17 PM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Thats a 2 year old thread, What is it you want to know?
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-TRANS, DP-TUNER LIVE, MBRP 4" SS, Isspro 3 gauge kit, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
  #13 (permalink)
Old 05-02-2009, 08:21 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
Quote:
sike!!! i thought Alan was back
__________________
Early 99 7.3 F350 auto,TN T-4 mount with a s467 for air,SRP 1.1 for oil,H-11 stud's,"NEW" alliant 315/200 hybrids, all supplied by unlimited diesel..shimmed 910's, DI push rod's, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck...
http://inlinethumb43.webshots.com/50...200x200Q85.jpg
  #14 (permalink)
Old 05-02-2009, 08:37 PM
jdecker88's Avatar
jdecker88 jdecker88 is offline
jdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to beholdjdecker88 is a splendid one to behold
Thats what I thought I was in shock LOL there will be a thousand views now LOL.
__________________
Justin (JD)
2000 F-250 CC SB 4x4
Roadside Help NetworkDP-Tuner Guzzle's Truck Site
Pete's Custom Filter Covers Riffraff Diesel Performance
Quote:
Originally Posted by megawatt00 View Post
Kinda tough to embrace the dark side when your an electrician.
Tags
2001, 60, 73, 73l, boost, diesel, disconnect, ford, line, powerstroke, red, tube, tubes, unplug, wastegate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
