16.5 " rim
Old 01-03-2007, 09:25 PM
fulltimehiboy's Avatar
fulltimehiboy
fulltimehiboy is offline
16.5 " rim
I have a early 1977 ford f250 hiboy. I was wondering if any one knew if there is any clearance problems with putting 16" rims on the truck if it came with 16.5" rims? thanks
Old 01-03-2007, 10:33 PM
whalerron's Avatar
whalerron
whalerron is offline
It will depend on the year of truck for which the 16" rims were made. Some of the earlier 16" rims will hang up on the front brake calipers.
Old 01-03-2007, 11:40 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
It does depend on what kind of 16" wheel your putting on. I have searched this topic before, because I am going to do the same thing. Everything that I have found, is that a 16" wheel should fit, and If you go with an aluminum wheel, than you may have to shave off a little of the caliper with a grinder, but not much to get clearance and not enough to damage the caliper. I have not tried it yet, but that's just what I have found. If you find out anything different let me know. Thanks.
Old 01-04-2007, 12:50 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
78 F250 2WD single piston calipers. 16" steel wheels just barely fit. Aluminum wheels would not have fit.
Old 01-04-2007, 04:00 AM
blown466ford's Avatar
blown466ford
blown466ford is offline
I have a 77 highboy 4x4 with dual piston calipers and 16's clear just fine. Just make sure if you have the big hubs your rims have at least the 4.75" hole and not the 4.5". I ran into that problem!!!
Old 01-04-2007, 10:58 AM
fulltimehiboy
thanks for the input. I think that I found a used 16X10 set. I am going to check them before i buy them. I am hopping to upgrade from mud terains to some boggers
Old 01-13-2007, 09:06 AM
Mach1s's Avatar
Mach1s
Mach1s is offline
I have a 79 F-250 4x4 supercab. I needed to but 3/8 wheel spacers in to keep them from rubbing on the dual piston calipers.
Old 01-13-2007, 10:50 AM
scottie2hottie's Avatar
scottie2hottie
scottie2hottie is offline
I have multiple sets of factory ford steel 16" wheels and they all fit my hiboy and used to fit my 78. my hiboy is drum front though.
Old 01-13-2007, 02:57 PM
Thomasm67's Avatar
Thomasm67
Thomasm67 is offline
Has a 76 Hiboy and went with simple Black Wagon wheel rims that are 16" and they went on fine no problems cleared the caliper's.
Old 01-13-2007, 03:43 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,108 Likes on 2,168 Posts
fulltimehiboy, where are you located?? i have a set of stock 16 inch steel wheels that came off an 88 F250. you can have them if you want them. they are in central jersey
Old 01-14-2007, 07:12 AM
vettman's Avatar
vettman
vettman is offline
16 inch wheels
I'm running 16-inch Alcoa aluminum wheels on my 76, F350 and no clearance issues with front calipers.
ryanben
34
04-23-2022 02:49 AM
lt dan
01-25-2019 01:08 PM
Hedgehog
1999 to 2016 Super Duty
01-20-2019 06:12 PM
ExSKARsion
11-27-2012 12:12 PM
loudfords
03-01-2001 07:52 PM
Quick Reply: 16.5 " rim
