code P1248, Please Help
Old 12-19-2006, 09:06 PM
twisted289's Avatar
twisted289
twisted289 is offline
New to this forum, I recently bought an 02 Excursion 7.3 4x4 limited. Ive been driving my x now for 3 weeks and wasnt feeling that it had the power my old 99 7.3 dually had. So i brought it to the dealer for them to do a scan while driving, it came up with a p1248 code, Turbo concerns. although no ses light had come on in the last 3 weeks. They said they traced it back to a poor connection at the map sensor. When i did a search on google for that code it came up as Turbo boost not detected, I hear the turbo more now after the visit to the dealer and $290 dollars, but does this make sense, or should i start looking into replacing the turbo?
Thanks John
Old 12-19-2006, 09:12 PM
Uzumati's Avatar
Uzumati
Uzumati is offline
The PCM determines boost by subtracting Barometric Pressure from MAP and decides how far to open the wastegate according to throtle demand. If the MAP is bad the PCM cant determine how much boost is being made. I would bet your turbo is fine.
Old 12-19-2006, 10:27 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
And so $290 later, how is it running now? Did they tell you what they did? Was the dually a stick? I'm assuming the X is an auto.
Old 12-19-2006, 10:45 PM
twisted289's Avatar
twisted289
I hear the turbo a little more when i first take off, but it still not as fast as my old truck which was an automatic. the dealer said poor connection at map sensor,they cleaned the connection at the map sensor and remapped the pcm. $130 was to hook the scanner up and road test so $160 to track down the problem and repair.
Old 12-20-2006, 12:44 AM
Tenn01PSD350
Man, I don't want to rant about the stealers so I will just say, check all of your intake boots to make sure you don't have a boost leak. That goes for the lines to the MAP sensor too. Check everything hooked to the intake side. A boost gauge would ID any problem here pretty quick.
Old 12-20-2006, 07:22 AM
pctjk's Avatar
pctjk
pctjk is offline
I had the same code on my 99 F250 7.3 PSD. I checked the hose that runs from the MAP sensor to the intake and found it to be cracked and hard as a rock. I replaced it cleared the code and has never returned. I'd check this hose. Then buy yourself an OBD II scanner from the local MAC Tool distributor. You can get one for about $100.00 and pull your own codes. Beats taking it to the stealer. Model #ET75 and comes with computer software to look up codes. Hope this helps all.
Old 12-20-2006, 07:58 AM
Uzumati's Avatar
Uzumati
Uzumati is offline
If you get a scanner make sure it is capable of reading enhanced manufacturers codes or you wont be able to pull all of the powerstroke codes.
Old 12-20-2006, 08:08 AM
twisted289's Avatar
twisted289
I did put a friends scanner on the truck when i was looking at buying it and no codes came up. From what ive read the $100 scanners dont do the trick, which is what prompted me to get it scanned at the dealer. If I knew i was gonna spend $290 at the dealer, I would have put out the other $100 and bought the DP tuner. Gonna look around under the hood today, the dealer told me to bring the truck back if I didnt feel the difference in a couple of weeks and they would rescan for free and go from there. They say its fixed, we'll see. Thanks for the replies, keep the ideas coming and Happy Holidays
Old 12-20-2006, 08:21 AM
Uzumati's Avatar
Uzumati
Uzumati is offline
Keep in mind that that dually probably had higher gearing than the Ex. so the SOTP feeling will be a little less in the Ex
Macmathews
01-28-2015 07:42 PM
mdayz28
07-13-2013 04:38 PM
sand1
05-11-2013 08:00 AM
Tormz
12-15-2011 11:41 AM
pacampora
15
12-23-2007 12:48 PM
Quick Reply: code P1248, Please Help
