p1248 please help
Old Dec 14, 2011 | 01:50 PM
Tormz's Avatar
Tormz
p1248 please help
1999 7.3 diesel all stock with a lift and35s it throws a p1248 and a lot of white smoke out the pipe and a loss of power please help i have had the truck for only a week
Old Dec 14, 2011 | 02:00 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Look at all your boots on the IC tubes for one that is leaking.
Give us more info, when did you notice this? Is it while cranking or going down the road?
Old Dec 14, 2011 | 02:24 PM
Tormz's Avatar
Tormz
While driving there's little power and I am not sure where to check I am new to diesel
Old Dec 14, 2011 | 02:45 PM
miller_feed
There are 6 rubber boots on the top of the engine. There are 4 on the tubes going to and from the intercooler. There are 2 orange ones under the spider going to the intake manifolds in the valley. I think one or more are leaking. Make sure they are in place and the clamps are tight.
Old Dec 14, 2011 | 03:34 PM
Tormz's Avatar
Tormz
There is small Leek coming from the hose under the yellow lever
Old Dec 15, 2011 | 12:31 AM
DND58's Avatar
DND58
Tormz, sounds like a leaking fuel bowl drain valve. Have a look at these links.
http://www.dieselorings.com/docs/FuelDrain.pdf
Replacement O-rings for Ford Diesel Engines
Bob at Diesel O rings is a great guy selling quality stuff with fast, professional service.
Old Dec 15, 2011 | 10:57 AM
Tormz's Avatar
Tormz
It's a small drip every 2 seconds. That is causing all the white smoke and loss of power?
Old Dec 15, 2011 | 11:01 AM
miller_feed
No, that (water in fuel drain) valve will not cause that. Did you check the rubber boots I mentioned?
Old Dec 15, 2011 | 11:07 AM
Brother Les's Avatar
Brother Les
So how much is leaking out the tube under the engine? It will take you ten minutes to fix the drain valve once you get the parts.
Old Dec 15, 2011 | 11:09 AM
Tormz's Avatar
Tormz
No cracks they were tight
Old Dec 15, 2011 | 11:13 AM
Tormz's Avatar
Tormz
I plan on fixxing it. Thanks for the link. It has a drop every few seconds
Old Dec 15, 2011 | 11:36 AM
BIGTERRY75's Avatar
BIGTERRY75
Did this happen all of a sudden?
Do you know what you are doing?
If you don't know take it to a mechanic, we have lots of tools and equipment to get it done right the first time instead of replacing things that are not broken.
Check your MAP sensor and hose from intake to MAP first. You really need a good scan tool that shows MAP data to test MAP. You will need to apply air pressure to MAP and watch voltage to ensure if MAP is good.
Then check manifold crossover for leaks and also inter cooler and its feed and return pipes and fittings. (as mentioned above)
If all is good there most of the time its the TURBO. Take it off and have it rebuilt.
Old Dec 15, 2011 | 11:41 AM
Tormz's Avatar
Tormz
I just got the truck and two days later the light came on with all the other problems
transmogrifiednow
May 22, 2017 09:41 PM
zachbrown0413
44
Jun 16, 2016 08:14 AM
JustinXTLR
May 8, 2011 11:02 PM
jkesselri
Jun 19, 2009 03:00 AM
ffordman46095
Aug 7, 2006 08:47 PM
