tires
Old 12-15-2006, 05:49 PM
j tate's Avatar
j tate
j tate is offline
tires
i was wondering if i could run 265/75/r16 tires on my truck or are they to wide?
Old 12-15-2006, 07:36 PM
2jhanna's Avatar
2jhanna
2jhanna is offline
i can check tomorrow, but i think that size is what we are running on both our duallys.
the `90/f450 has 10 lugs wheels and the `97/f350 has 8 lug.
Old 12-15-2006, 08:39 PM
seanvicious's Avatar
seanvicious
seanvicious is offline
i have 265/75R16s on my truck. my brother has 285/75R16s on his. no problems.
Old 12-15-2006, 08:53 PM
j tate's Avatar
j tate
j tate is offline
then reason im asking is because after i mounted the tires on the truck i looked to see if the tires were rubbing together and they are touching, thats not good they can get hot and cause them to blow out cant they?
Old 12-15-2006, 09:49 PM
2jhanna's Avatar
2jhanna
2jhanna is offline
i stand corrected, i checked our 2 trucks, they both have 235/85/16's. that is stock size.
Old 12-15-2006, 10:56 PM
dieselbogging's Avatar
dieselbogging
dieselbogging is offline
I had 315/85/16 on my truck and they were close but i ran them for 75,000 kms. never had a problem.
Old 12-16-2006, 01:00 AM
banks7.3's Avatar
banks7.3
banks7.3 is offline
you could use spacers between your rims. jeg's has 1/4" spacers for $15.00. cheaper than swapping tires. i know you can find them wider elsewhere also. here is a link to jeg's, the ones you need are at the bottom of the page. it is up to you if 1/4" is wide enough.
http://www.jegs.com/webapp/wcs/store...10002_18581_-1
Old 12-16-2006, 10:12 AM
j tate's Avatar
j tate
j tate is offline
thanks banks and everybody else for the replys my major question is with the tires barely touching will it cause the tires to heat up and blow out?
Old 12-16-2006, 10:59 AM
banks7.3's Avatar
banks7.3
banks7.3 is offline
i have heard that they will heat up also but cannot confirm that. the other problem you have is with mud getting forced in between the tires, with no way for the mud to get back out. this could cause a vibration from the tires being out of balance.
Old 12-16-2006, 05:22 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
Do you put any weight on your truck?
If they are touching they will get hot.
If they are touching on an empty truck, they will really be touching when you add weight.
Yes dual tires that touch between the tires will cause them to blow out from all the heat created.
If you want to run wide tires on a dually, you can get a set of spacers that lets you run duals on a SRW truck and install them between the wheels. I have seen 315 tires on a dually before. But those spacers are close to 500 dollars a pair the last time I checked them.
Pitt4212
6.7L Power Stroke Diesel
12-09-2011 09:37 AM
bnrv99
2004 - 2008 F150
01-10-2010 07:45 AM
HMS
1999 to 2016 Super Duty
21
12-11-2009 10:47 AM
tomas428
Offroad & 4x4
07-02-2006 11:03 PM
dshupp
2004 - 2008 F150
09-24-2004 03:30 AM
Quick Reply: tires
