Brake problem
Brake problem
Hi, all
I just had my brakes done, new pads and routers on the front, after the brake job the pedal was soft and I would hear a loud pop while baking hard. Anways, I took it back and they said there was air in the lines and that the rear pads needed djusted, they did that and know when stopping lightly the abs system engages, it doesnt do it at hard stops, and only dose it once and a while. Any Ideas?
thanks
mike
thanks
mike
Yes, likely a bad ABS speed sensor. There are 2 recent threads (mine and another's) on exactly this subject with good feedback support from the FTE members. Basically, you will need to diagnose whether it is the front or rear and repair expense difference between the two is substantial. If the dealer did the brake repair job for you I would have them pull the codes to see which sensor is the problem. Did the problem occur before your brake job.....if it is the front, possibly your brake mechanic damaged the sensor or cable during the brake rebuild. I am anxious to know how things turn out so please report back. Good luck.
What year and model is your Ranger.
https://www.ford-trucks.com/forums/5...low-stops.html
https://www.ford-trucks.com/forums/5...99-ranger.html
99 Ranger, Supercab, 3.0L Flex, 5spM, 4WD w/ off-road
Here's additional info in the Read First section that may be applicable depending on the year of your Ranger.
https://www.ford-trucks.com/forums/1...-problems.html
stangman516
05-12-2009 02:22 PM
