Sponsored by: Real Truck
Brakes
Old Apr 5, 2009 | 03:33 PM
MIKE1646's Avatar
MIKE1646
Brakes
Is time to replace the brakes I want to the get the Hawk Brake Pads but not sure which one to get, the LTS, Ceramic or the Super Duty. Any recomendations?
Old Apr 5, 2009 | 05:27 PM
ReAX's Avatar
ReAX
They both require some heat to warm up to operating temperature. However, the LTS run in a lower temperature range, which is more convenient for light duty towing and normal driving. The superduty pads run in a much higher temperature range, meaning they work optimally only when hot to really hot and work lesser at lower (normal cruising) temperatures. So if can keep them hot all the time, the superduties might be your better choice, but if your light on the brakes, then they probably will not stay hot enough to give you their best performance. In which case, the LTS will perform better for you.
hoagie48
Apr 27, 2013 10:17 PM
4BTF250
May 18, 2008 06:59 AM
tonysquirrel
Jul 25, 2004 04:59 PM
donna
Jul 20, 2000 11:03 PM
