proper oil pressure
Originally Posted by WALFORD'S 56
My 272 was not running for 15 years and locked up.I only have 21,000 original miles and thought that 60-65 psi was unusually high.It is clean as a whistle inside,and I am using 30 weight non detergeant oil.I heard my DAD say that is what the old trucks ran.I looked at your message board and you guys say other-wise!Should I change the 30 n.d.oil and if I do will I get a different oil press. reading? THANKS
I understand what you guys are saying about the high volume pumps. I do have the screw in plug at the timing chain. The pump I have is a Mellings pump. Initial startup gives me a higher volumn of oil to get oil to the upper valve train quicker. After the engine is a warm temps, it drops to a almost normal reading of 40-60 lbs. Back in high school, I was fortunate to have worked with Ed Pink Racing engines. Although the engines we built were 500+ HP, we did build engines for daily street rod use or occasional racing. We always used the same types of pumps. Ed Pinks philosophy was, "it's better to have too much oil pressure than too little or non at all". I've never heard of anyone having problems like you guys described before. I do agree that a stock pump is sufficient for a stock enging and probably a modified street performance engine as well. It's that rule of stock is usually better than modified to avoid problems. I've always been nervous when I see someones oil pressure at 5 lbs, and it only goes 20lbs at acceleration. Interesting info though, thanks guys. Makes me think???? So what is the purpose of having a deep oil pan or transmission pan for more capacity of oil?
High volume pumps are for race engines set up with loose mains and rods, which gives more HP but at the expense of engine life. They are shooting for a season's life. We have tighter clearances and are looking for years of life. If the pump produces more volume than can go to the system, it builds pressure and dumps back into the oil pan via the relief valve.
