runs rough when cold
Originally Posted by tim73
Does it appear to run rich? Check your Engine Coolant Temp Sensor(It controls how much fuel the engine burns until it is warm enough for the O2 sensor to take over)
Originally Posted by unger316
hey guys
heres my problem, my truck runs rough and has no power when its cold, but once it starts to get warm it runs fine. it seems to only happen when its cold outside, if its 45 or warmer outisde it runs fine.
thanks, chris unger
87 f150 302 4x4 a4od
thanks, chris unger
The engine coolant temp sensor is located in a tee on the front of the intake directly below the throttle body. The engine coolant temp switch, which runs the gauge, is located on the driverside front part of the head with a one wire hook up. If your the guage isnt coming up and the motor feels fairly cool to the touch and not warm or hot to the touch, then change the thermostate before you start buying more expensive parts like sensors. As for it running better when warm outside then try looking at the air charge temp sensor which is located on the intake to the driverside, right between the front two fuel injectors. www.fordfuelinjection.com goes through how to check them with a voltmeter. The truck relies on both of these sensors to determine fuel mixture during the warm up portion of run time.
Michael Unger
27
12-12-2008 09:02 PM
unger316
36
12-13-2006 06:37 AM
