Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 11-09-2006, 09:57 PM
Kep4's Avatar
Kep4 Kep4 is offline
Jäger
2011 Ford F-350
Kep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant futureKep4 has a brilliant future
EGT probe placement
I was reading the thread by Matt regarding melting pistons, etc.
Since the 6.0 passenger bank seems to be the side which gets overheated and destroyed, would it make more sense to put the EGT probe in the passenger side exhaust manifold? I'm talking about mildly modified 6.0 engines, not a full on race engine.
Thanks!
__________________
Russ
'12 F350 Lariat CCLB 4x4 6.7, Bilstein shocks, AmpSteps, Highway Products tool box, Duraflaps, no HPFP failure worries
'12 Fuzion 305
'05 F250 Lariat CCSB 4X4 6.0 - Sold 4/26/11 w/96,500 miles
  #2 (permalink)
Old 11-10-2006, 02:55 AM
SpartanDieselTech's Avatar
SpartanDieselTech SpartanDieselTech is offline
FTE *******
Garage is empty, add now
SpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to allSpartanDieselTech is a name known to all
Thanks!
On first thought one might think so, but if you take a cumulative look at the situation I don't think it matters.
According to what I've found so far in my research, EGT difference between cylinders or banks isn't a problem. Its the fact that the passenger side isn't able to cool the pistons as efficiently, and as an effect the piston temperature is increased even at the same ambient cylinder temperature- therefore I don't think its something you will ever see on a gauge.
Not to say I think it would be a bad idea; I think it would be a great idea to ditch the transmission temp gauge (if you don't tow) and install 2 pyrometers, one for each bank. If you did come across a cylinder contribution problem it would immediately point to the problem bank, which would help in diagnosis. They even make an EGT "Red Alert" system sold by Summit which has 8 probes and monitors each cylinder individually to monitor cylinder temperature and contribution...pricey at 1000 dollars, but no doubt effective.
  #3 (permalink)
Old 11-10-2006, 08:42 AM
Kep4's Avatar
Jäger
2011 Ford F-350
Thanks Matt!
You had talked about two EGT gauges in another thread awhile back and that's a great idea. I've got Isspro EGT, boost and trans temp gauges already so adding another EGT gauge just means getting a quad pillar mount.
I tow a heavy toyhauler trailer over the Grapevine frequently and I like to get where I'm going ASAP. I also can't repress the urge to pass the competition when towing and smile as we fly on by! Guess that means transmission upgrades aren't too far off....
__________________
Russ
'12 Fuzion 305
Tags
60, alert, correct, cylinder, diesel, egt, egtprobeplacement, engine, ford, guage, location, placement, placment, probe, probes, red, review
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
