1966 Moldings:
1966 Moldings:
I got my truck painted and have put my side moldings back on.I have encountered two problems now!The first is that all the moldings look straight up to the hood piece.The hood molding sits down about a 1/4 of an inch.I used a rust free hood from a custom cab 1965.I can't raise the hood anymore at the back because it is level with the cowl..The other problem is the cowl moiding rubs the the door as it is opened,so I had to slide it forward some.Has anyone else had this problem? Any help would be appreciated!Thanks,Russell
1966 Moldings:
John, I know about the nuts I had all the molding off of my truck.You can get some movement but not much.I thought the holes might be off on this hood some,but they should be the same!As for the cowl moldings I can not understand why the clearance is so close to the door as it opens!Thanks,Russell
1966 Moldings:
>be off on this hood
>to the door as it
This may be a silly question, but did you put the tapered part of the cowl moulding towards the door?
Nathan
>be off on this hood
>to the door as it
Nathan
1966 Moldings:
I just read your message again, I see what the problem is the new hood holes were probably drilled wrong at the factory or from a different factory that does happen. anyways if you have rubber washers between the clips and the body I would take them out that way you could move the coul down 1/8 and the hood crome up an 1/8 its worth a try ......Rich
russell56443
03-25-2005 03:55 PM
russell56443
01-25-2005 01:08 PM
Russell Leonhardt
02-19-2001 11:13 PM
