Is an exhaust manifold leak something that can cause problems?
Old Jan 21, 2005 | 11:15 PM
russell56443's Avatar
russell56443
Hi everyone,back again with another question.
The O2 sensor and Seafoam fixed my milage so far but I have noticed I have an exhaust manifold leak thats been getting worse slowly.
Will this cause any problems long term?
I can replace it soon but its chilly here in Minnesota so if I can wait a while that would be cool?
Thanks for any info,
Russell
Old Jan 22, 2005 | 04:34 PM
Tailhunter18's Avatar
Tailhunter18
Where exactly is the leak located....connection to the pipe or just in the manifold it
s self??
Old Jan 22, 2005 | 05:06 PM
tex94F250's Avatar
tex94F250
Depends on what the leak is directed at. If its a plug wire it may be an issue. Where is the leak (as above post?).
Tex
Old Jan 23, 2005 | 02:06 AM
russell56443
Hi,thanks for responding!
It's above the second plug toward the front of the truck on the left side.
I was worried about the exhaust valves ect..hopefully it's not going to cause problems there.
Thanks for any info you can offer!
Old Jan 23, 2005 | 06:43 AM
tex94F250's Avatar
tex94F250
The leak would have to be a little more than jus a crack in the iron to cause a temperature issue with the exhaust valve at that point. Jerry brazed a crack in an F 350 that was open to access on top pf the manifold about two years ago and it's still in place. Caution, the truck is used only to haul hay/trailer on the farm and he is very good with the brazing torch. Don't know what the longevity factor would be on the highway with a constant, everyday use thermal cycle.
Tex
Old Jan 25, 2005 | 01:08 PM
guzzler96's Avatar
guzzler96
Post
You can get a replacement manifold somewhere like 1-a auto parts for between $50 and $75 for most of these trucks. If you drive it everyday it was a matter of how long I could stand the gushing sound that the leak made until I fixed it.
guzzler96
russell56443
Nov 19, 2005 11:14 AM
russell56443
Mar 25, 2005 03:55 PM
Russell Leonhardt
Jan 28, 2001 04:58 PM
