Squeaky clutch spring:
Old Feb 16, 2001 | 09:58 PM
Russell Leonhardt's Avatar
Russell Leonhardt
My clutch pedal is noisy.The noise comes from the spring.I have tried all types of lubricants including WD-40.It stops for awhile but comes back.Has anyone had this problem,and yes I want to keep it 3 on the tree like Henry built it! Thanks,Russell(1966 352 Custom Cab)
Old Feb 16, 2001 | 10:12 PM
StockMan's Avatar
StockMan
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
I suspect your missing the plastic/nylon insulators that are designed to go on each end of the pedal assembly where the spring attaches. It is quite common for these to be missing after they break. The easiest way to remove and attach the spring for replacement of these items is to remove the whole pedal assembly. Once out you simply rotate the clutch pedal backwards. This loosens the large spring for one hand removal (no kidding). You simply replace the insulators, reattach the spring and clock the pedal back around. Don't waste your time trying to replace these with the pedal installed. The spring is quite dangerous under that load and, even assuming you can get the spring out, the insulators will keep busting as you try to replace them. Don't ask. :-)
[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/registrysig.gif]
Old Feb 17, 2001 | 06:04 AM
jowilker's Avatar
jowilker
Rusty, I guess we all have experenced that one. If you do what Stockman suggested, you can apply some white lithiumn (sp) grease on the area. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01]
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners]
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Feb 19, 2001 | 10:15 PM
frank_1's Avatar
frank_1
where do i find these new nylon bushings???
j. frank
Old Feb 19, 2001 | 11:13 PM
hpguy's Avatar
hpguy
leonharu
Apr 11, 2009 08:22 AM
Snowking
23
Sep 9, 2007 12:50 PM
leonharu
Dec 26, 2006 11:10 AM
Hiexcur
Sep 25, 2002 08:34 AM
1968F250LWB
Jun 6, 2002 07:58 AM
