93 F350 Gcwr
That seems on the low side to me. By what you're reading, a DRW automatic with 4.10 gears can only "legally" pull a 7900 lb trailer? I'm looking at a 29' 5th wheel built in 92 that weighs over 9500 lb. I know there are 35-40' available that weighed well over that.
Or is 13K for max trailer weight? I thought the combined would be closer to 20K lbs. Am I understanding you wrong?
Jason
Jason
The IDI engine is not noted for HP. it is only rated at 185 HP and yes it is the combo 13K lbs and tow rate of 7900# trailer. I have towed my 29 ft TT and it weighed in at 8500 and it was all it wanted to pull with a 5 sp with 4:10 rear. Especially up grades of over 4%. The fifth wheel might pull a little easier depending on the sail area of the front of the trailer.
Is there a big difference in weight capacity between the 460 and the Diesel?
I'm not concerned really with the performance of the IDI. My plans call for a Cummins 24V engine swap down the road. I've pulled many trailers that weighed over 10K lbs, just not on a regular basis. The IDI doesn't do it quickly, but it gets the job done.
Jason
Jason
This is right from the Ford Recreational vehicle and trailer towing guide 1992-3....
The GCWR of the Fseries trucks towing a frame hitched trailer.
F series with 7.3 and automatic is:
355....12000lbs
410....17000lbs
F series with 7.3 and manual is:
355....12000lbs
410....14000lbs
The CGWR of the Fseries trucks towing a Fifth wheel trailer.
F series with 7.3 automatic is:
355....12000lbs
410....17000lbs
513....18000lbs
Fseries with 7.3 and manual is:
355....12000lbs
410....14000lbs
513....17000lbs
355....12000lbs
410....17000lbs
355....12000lbs
410....14000lbs
355....12000lbs
410....17000lbs
513....18000lbs
355....12000lbs
410....14000lbs
513....17000lbs
tawilson1152
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-02-2004 10:13 AM
