fuel pump pressure
Old Sep 27, 2006 | 08:03 PM
kenpobuck's Avatar
kenpobuck
fuel pump pressure
How much pressure do you need to feed the injection pump on a NA 6.9? Is 7-9 psi enough?
Old Sep 27, 2006 | 09:27 PM
sailors30's Avatar
sailors30
That's the pressure I was told on this site, to look for when checking out the lift pump.
Old Sep 28, 2006 | 06:31 AM
PLC7.3's Avatar
PLC7.3
Normal manual lift fuel pump.....
Pressure Rating: 4 lb - 6 lb
Gallons Per Hour: 23
Old Sep 28, 2006 | 08:15 PM
kenpobuck's Avatar
kenpobuck
Thanks guys that helps alot.
Old Sep 28, 2006 | 09:25 PM
flyboyd8's Avatar
flyboyd8
I actualy have a gauge in the fuel line just before the IP, and my lift pump holds 4.5 PSI on both Dino fuel and WVO. The Ford Repair manual states 2 PSI Min. I found that 9 to 10 was to much for my IP, it seemed to effect its timming advance.
oldford65
Aug 7, 2013 10:19 PM
dr strangelove
Sep 9, 2010 04:13 PM
okaw
Oct 12, 2006 11:11 AM
ScottJM
Aug 4, 2004 04:29 PM
EJR Chase
1983 - 2012 Ranger & B-Series
13
Sep 11, 2002 09:11 PM
