fuel pump relay chatter 2nd question
1991 f-150 5.8
on my last post i was told to ground the wire at the test plug to see if the chattering of the relay would stop. i did this and the relay stopped chattering. is this a permanent fix. do i leave it grounded or do i have to look for a ground at the EEC. if so where is the computer located or does someone have a diagram that would help me out. thanks. john
thanks a lot subford for your input and the diagram. from the looks of it power to the fuel pump relay comes from the EEC power relay. i will replace the power relay just in case that it is causing the problem of the chatter. thanks again. john
i tried restarting the motor and when i turned on the ignition the fuel pump ran constantly and the motor would not start. i grounded the fuel pump relay and the chattering was still there. i ran a code check and a code 15 came up on the scanner which is related to the computer memory. after running the scanner the moter would start for about 8 times then it would go back to the chattering and no start also the tad and tab relays were also chattering. i guess that the computer is at fault. if you think that that the grounds 40 and 60 are in question let me know. i think that the computer is under the radio mid dash area. i was told that it was located on the left kick panel but all of the wires lead to the mid councel area. any help will be appreciated. thanks again. john
superdutyf450
11-24-2014 09:32 PM
