Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- How to Reprogram Door Keypad Code
Step by step instructions for do-it-yourself repairs
Keyless Keypad Code
#61
#64
The following users liked this post:
#67
#69
I have checked with my Ford Repair manual DVD's and have found that the module is called 2 different things depending on what year Excursion you have. I also found that the module is located in 2 different places. If anyone uses this, finds the keypad codes on the 200-2001 module, please do a photo write up of it and submit it as an article!!!
In the 2000-2001, it is called the Generic Electronic Module (GEM) —Generic Electronic/Central Timer (GEM/CTM) and is located behind the fuse panel. You have to dismantle the fuse panel to get to it.
2001 -02 instructions From the Ford DVD's:
The GEM controls a variety of systems:
5. Position the instrument panel fuse junction panel aside.
In 2002 and up, it is located behind the radio in the center of the dash and it is called the Vehicle Security Module (VCM).
The VSM controls the following systems:
remote keyless entry (including panic feature)
computer-operated locks
autolamp
keypad keyless entry (Excursion only)
- 4-wheel drive functions
- front and rear interval wiper/washer
- warning chimes
- keyless entry
- interior and exterior lamps
- power windows
- Remove the instrument panel steering column cover.
- Unlock the retainers.
- Loosen the bolts.
- Remove the nuts.
- Remove the bolts.
- Remove the generic electronic module/central timer module (GEM/CTM).
- Disconnect the electrical connectors.
- Remove the screws.
- Remove the GEM/CTM.
- To install, reverse the removal procedure.
autolamp
#70
Thank You for the help!
I have a 2003 Eddie Bauer EX and my door code was not in my paper work and the Ford dealershipship wanted the truck for sveral hours and an unknown price to get me my code. Everyone that has posted here helped me to find mine and the keypad now works! I took the trash bag holder out then the drink cup holder. I then looked to the left and was able to find the code! It was rather hard but like you guys said a good flashlight and alittle searching has me now being able to use the keypad. Thank everyone!
#71
#73
matt if possible, could i also get a copy of that document sent to me, i'm tired of trying to find the code,
jomarjosh@hotmail.com
#75
