rain gutter on roof
rain gutter on roof
I noticed some surface rust along the rain gutter along the front of the roof and wanted to sand it off and re-prime. There looks to be some kind of putty or some thing in the groove between the rail and the roof, what would I use to replace it with if I remove it? I'd like to remove it so I can be sure to clean out all the rust before it goes too far.
rain gutter on roof
[updated:LAST EDITED ON 17-Jun-02 AT 09:41 AM (EST)]Sandblast it all out, rust and old sealer. Prime and paint it. Then run a bead of clear silicon caulk down the whole length of the gutter to further seal any gaps. Keep the bead thin using a piece of wood dowel that fits down in the groove. This is to prevent from filling up the whole gutter and rendering it useless. Wet the end of the dowel to prevent the caulk from sticking to it. Have fun and good luck.
Russell
1968 F250, 300CID I6, C4. A beauty slowly coming together.
Russell
rain gutter on roof
The proper name for what you need is seam sealer. I know you can purchase this at NAPA stores.
I have dealt with the problem you are having and have fixed it successfully.
1. Sandblast
2. Brush a product called extend over the rust. (Be sure not to
get this everywhere since it is not easily sanded)
3. Put in seam sealer.
4. Wait approximately 72 hours before painting over the seam sealer
or the color of the sealer will blead through the paint.
You don't want to use Bondo in this area of the cab because it flexes alot and will crack(Trust me). Let me know if I can be of further assistance.
1. Sandblast
2k
ford_dude0411
03-14-2017 04:24 PM
annaleigh
07-18-2015 09:30 PM
hppydrunk
05-03-2007 12:36 AM
