1999 Expedition NO REVERSE,,,Help
Old 04-13-2006, 05:17 PM
BigMan69's Avatar
BigMan69
BigMan69 is offline
Hey everyone,
I have a 1999 Expedition XLT, 5.4L, 4X4 with 88,000 miles. All has been fine with the truck and tranny. Had the dealer replace the spark plugs on Monday and all has been fine the last 210 miles. Drove the truck all day today then went to go back out and BAM,,, no reverse at all. No noises before this happened, no noises when you put it into reverse, just nothing. Fluid is nice and pink, proper level, changed about 24,000 miles ago (full flush). Any ideas??? Just seems weird how it happened all of a sudden and a short time after the plug change. Any help would be appreciated.
BigMan69
Old 04-13-2006, 07:14 PM
BigMan69's Avatar
BigMan69
BigMan69 is offline
Any ideas??? I might be heading off to the stealership in the morning if nobody's got anything.
Old 04-14-2006, 02:48 PM
l-m tech's Avatar
l-m tech
l-m tech is offline
do you have all the forward gears.if you dont i would suspect a broken sun gear shell.
Old 04-14-2006, 03:35 PM
BigMan69's Avatar
BigMan69
BigMan69 is offline
Yes, all forward gears are good. Check this one out,,,,this morning the truck was perfectly normal. Drove fine in drive and reverse. I still went to the stealership for them to check but they said all was OK, couldn't find any problems. Really weird.
BigMan69
Old 05-19-2006, 03:28 PM
BigMan69's Avatar
BigMan69
BigMan69 is offline
Well,,,,92 miles later the tranny blew. So much for the stealership doing a diagnosis and saying all is fine. Had it rebuilt by a reputable tranny shop I know and it sure was expensive. Needed a forward planetary assembly, reverse planetary assembly, solenoid switch assembly as well as the usual parts on a total rebuild. Came to $2900,,,,whew.
benbuilder
13
06-19-2017 06:47 AM
Sterling6.7
1997-2006 Expedition & Navigator
12-18-2016 02:40 PM
nick112288
11-09-2016 05:08 PM
Nate3798
1997 - 2003 F150
10-11-2016 06:19 PM
Rajczak
03-04-2010 09:53 AM
Quick Reply: 1999 Expedition NO REVERSE,,,Help
