86 bronko engine swap help please.
I have an 86 bronko with a EFI 302 and a NP435.This rig is being done up for rock crawlin.I love the fulie injection but the 302 never has enough power.I have all the stuff to convert a 460 in the truck but wanted to know what is involved in swaping the wires for the EFI 460 over the EFI 302???What has to go and what can stay for the 460?Please help.Also I still need all the EFI equipment for the 460,so what is needed and what can be used in the truck now?
well i will tell ya that the 460 for rock crawling is not the way to go. way to heavy of a motor for that type of wheeling. you need to get your front/rear gears taken care of to handle the rock crawling. running 4.88 or 5.13 gears would take care of your need for more power. along with that np435's low gearing would be sweat setup maybe even run a 2 transfercases as well.
but if your really stuck on doing this just say so and i will continue .
I have the 460 now that i just built but its got a new eddelbrock intek and carb.In the truggy.I am going to the bronko with a fulie 302 and can run that till I find all the 460 fulie equip.I will never keep the 302 so please help.I have been runnin a 6k pound truck for a while and love it.I do all sorts of wheelin along with rocks.So please help.
Thanks,,,Will.
Thanks,,,Will.
ok, a think even a 5.8 stroked to a 393 or 408 would be a better, lighter choice and easier to efi as well.
your gonna need a new bellhousing for that np435 so it bolts up to the 460. L&L products has the proper mounts and maybe even the bellhousing youll need to. it may be spendy but worth it in the long run. the 302 harness should work on the 460 as well from what i have been told. you would just need the proper ecu from an f250/f350 with a manual tranny. also look into some new front springs to handle that extra weight or look into going SAS upfront which in my mind would be the best solution. the ford TTB just doesnt do well rock crawling.
Philippi
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
08-11-2011 06:40 AM
