Ranger Clutch Change
#31
#32
My truck has always been a little difficult to get into First about half the time. It hangs up just a hair about halfway into the gear, but it has done this forever and i just got used to it. If i put it in first just before i complete my stop it goes right in. Eventually when i need a clutch and a slave i'll find out and report back. My throwout bearing has been noisy forever too. It makes a rattle sound in neutral with the clutch out. Oh well i just live with it, I love my truck. Everything works, it just has a few quirks.
#33
#34
#35
that is all new to me.........here is my test..........idle the truck with the gear box in nuetral and the clutch depressed........if it makes a noise it is either the TB or the PB...........
#36
Every bad throwout bearing I have seen has been the opposite......when the bearing was under pressure(clutch depressed) you would hear a noise. ..I wonder if your slave cylinder is loose or maybe where the throwout bearing sits in the slave is loose?
#37
Bleeding video is great
it should just click in.... did you replace the slave? did you replace the cutch master? have you seen these videos
YouTube - Ford Ranger & Mazda B-Series Pickup Clutch Hydraulic Release System Bleeding Procedures
YouTube - Removal and Servicing of Clutch Master Cylinder to Slave Cylinder Connections
Thanks for the link to a great video!
itsaprintshop
06-11-2012 02:53 PM
