New 4R75E transmissions on newer F-150's
Old 12-19-2005, 11:35 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
The 4R75E (V8) and 4R70E (V6) do look like an AOD or 4R70W. They still have a pan, filter and dipstick.
So far the only transmission in a Ford truck that doesn't have a dipstick is the 5R55S in the Explorer. It still has a pan and filter too.
Old 12-20-2005, 01:27 AM
Doctor7474's Avatar
Doctor7474
Doctor7474 is offline
Ford or GM have not designed a new from scratch rear wheel drive electronic automatic transmission ever thats available to the public.
The 4R70W/4R75's are nothing but AOD's. It went like this, They built the AOD, then decided to turn it into an electronically controlled transmission and renamed it AODE (E stands for electronic), they redesigned the solenoids and some of the electrical components and renamed it the 4R70W, now they have redesigned some more of the electrical components and renamed it the 4R75E or what ever it is. The basic trans (case, gear train) are the same thing that the old non-electronic AOD trans had. You can use the same filter and pan gasket that went in the old AOD's.
Like wise with the old E4OD transmission, which has been renamed the 4R100.
The 5R55 transmission are Mazda built, Ford uses them in Ranger/Bseries Mazda's, Explorer's, Lincoln LS's, Jaguar S-Types, and the new Range Rover. They no longer have dipsticks, they do however have a plug where the hole for the dipstick still exists in the case, and they still have trans pan's, and filters.
As for GM it went something like this, 700R4 became the 4L60E which still exists, its just a 700R4 with electronics added.
So basically they hare using 15-20+ year old designed transmission, and now they are saying you don't have to service them? I'm servicing mine every 30k I don't care what Ford or anyone else says. Trans fluid breaks down just like any other fluid that is subjected to pressure, heat, and contaminants.
Old 12-20-2005, 06:25 AM
BlackFX4Screw's Avatar
BlackFX4Screw
BlackFX4Screw is offline
Has anybody changed it thereselves yet.
Old 12-20-2005, 08:09 AM
CMOS's Avatar
CMOS
CMOS is offline
+1
Agreed!
CMOS
Old 12-20-2005, 10:17 AM
FX4GT's Avatar
FX4GT
FX4GT is offline
Ford DOES call for transmission service EVERY 30,000 miles. Refer to the owners manual.
Old 12-20-2005, 10:43 AM
BruceFX4's Avatar
BruceFX4
BruceFX4 is offline
Will an aftermarket pan for a 4R70 fit the 4R75? It would be nice to have a drain plug and a couple of quarts extra capacity.
Old 12-20-2005, 12:14 PM
Vizsla_Buddy's Avatar
Vizsla_Buddy
Vizsla_Buddy is offline
What ever it is, it shifts smooth as silk and pulls all day long.
Old 12-26-2005, 08:40 PM
1workhorse's Avatar
1workhorse
1workhorse is offline
Originally Posted by ford390gashog
i guess no one here has seen one. there is no pan to drop or filter to change. they are 100% sealed , not even a dipstick.
What year do you have? My 04 has a removable pan with a dipstick. I serviced it at 33,000 miles. I hope Ford isn't going to sealed units like they have with others. I have an 03 Explorer 4.6 with the 5R55E trans. It leaked fluid after the dealer overhauled the tranfer case, had to have it towed in because of no dipstick to check fluid level, kinda like a gas tank with no gauge! not a bright idea
Old 12-26-2005, 08:47 PM
1workhorse's Avatar
1workhorse
Shouldn't be a problem, if you get a deeper pan, make sure the filter is for the deeper pan (should come with the pan). It is the same design since the early '80's for the pan, and the early '90's for the filter.
Old 12-26-2005, 09:03 PM
1workhorse's Avatar
1workhorse
Yes, 10mm socket, short extension and ratchet, wide pan so you don't spill everywhere, and 5 quarts of Mercon 5 fluid and a filter kit for a 4R75W will take care of it. I change mine every 30,000 miles. I owned a E250 5.4 cargo van, traded it in at 78,000 miles, trans fluid was as pink as new, a relative of mine has never changed his, his fluid is now dark with 85,000 miles. Same type of driving, weight, engine, vehicle.
04 Ext. cab 5.4
Old 12-26-2005, 10:16 PM
nixer's Avatar
nixer
nixer is offline
Originally Posted by CMOS
I just checked under my hood and chassis - I also have a tranny dipstick and a tranny pan with a gasket (labeled " this transmission pan is equipped with a reuseable gasket")
CMOS
i thought all ford trans filters were reusable
Old 12-26-2005, 10:18 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
no its not the filter its the gasket which is reuseable. but can only be torque down 3 times.
  #28
Old 11-20-2007, 02:02 AM
Fosters's Avatar
Fosters
Fosters is offline
smooth as silk isn't exactly the best thing for it... these trannys need to shift a lil' faster, they're downright sloppy stock...
  #29
Old 01-10-2009, 11:00 PM
KD5NSS's Avatar
KD5NSS
KD5NSS is offline
I have an '07 supercab 4x4. I checked with the dealer and it has the 4r75e. The user manual does have service intervals listed for it. My manual says that its sealed for life, but under normal driving conditions to service the transmission at 150k or under severe conditions or if you tow to service at 30k. I have always operated under the philosophy of "oil is cheap, parts aint" so i follow the severe schedule for everything. Btw I have done the transmission service on my f150 already and it does have a filter. even the 5r55 in the mustangs and explorers that dont have a dipstick still have a filter and removable pan.
anton5052
08-21-2017 08:20 PM
Ford Big Rig
04-14-2017 06:07 AM
labman1014
04-12-2016 09:56 AM
Nightrain
11-18-2007 07:35 AM
ssd
1997 - 2003 F150
37
01-08-2006 08:56 PM
Quick Reply: New 4R75E transmissions on newer F-150's
