'79 F250 Rear Brake Drum removal??
I have a '79 F250 Pick-up with a Dana 61 rear axle, 8 lug wheels. I am in need of info/procedure to remove rear brake drums for inspection. I know I need to remove the axle flange screws and pull axle out. What size socket is needed to remove bearing nut, and who makes the socket, source, MAC, Snap-On, etc.? Is a special thin wall socket required? Also, what comes out of the bearing area next? Any shims? Any other precautions I should be aware of? Any torque values on nut, or just adjust nut tightness to give a snug feel on wheel bearings similar to a front wheel bearing? Thanks for any advice, suggestions. John
not sure if your axle is the same as mine. trying to find out in the clutch, transmission, differential axle and transfer case forums right now (with little to no success). not sure if mine is a dana 60 or dana 61. but anyways, i had this same problem recently and hit every parts store in the area. no one had or had ever even heard of one of these sockets. then i went to napa- finally someone who wasn't a complete idiot got me what i needed. it was a 2 9/16" socket made from cheap stamped steel. only about $15 if i remember right, and they had it in stock. my truck is a 77 f250, 400, c6.
you may need to replace the axle seals after you pull the axle, and it would be a good idea to have a catch pan handy cuz when you pull the axle oil will spill everywhere.
GeneGregory
04-26-2016 07:54 PM
Johnny Be Cool
17
10-05-2015 09:46 PM
jim henderson
03-23-2010 07:44 PM
