Rear Hubs and Drums / Dana 60
I am going to pull the hubs and drums off my 79 F350 soon to check the brakes and service the bearings. What parts do I need to replace new besides the seals , axle gaskets, I read somewhere that I also put in new flat washers for the axles bolts and the bend over locking ring between the adjuster nut and lock nut .
Gene
Gene
Here is some info and a possible option to those obsolete washers?
Dana 60 full floater - Rear wheel bearing adjusting nut - 50 -80 ft lbs, back off 1/4 - 3/8 turn. (Check for play). Lock washer - bend a tab or two over the adjusting nut, or use the same bent ones in the same place.
wheel bearing locknut - 90 - 110 ft lbs.
Axle shaft retaining bolts - 40 - 50 ft lbs.
Between 65 and 75 ft lbs.. spin... tighten.. repeat.. repeat... repeat... until torqued,, then back off 1/4 turn... put on lock washer.. put on second nut.. torque to spec.. then bend tabs over both nuts.. in either direction.. in at least two places on each nut
2 9/16 thinwall axle nut socket...1/2 inch drive, I bought mine at oriellys out of their catalog.
This one is for those of us with Dana 60/70's. The usual spindle nut set of 3 pieces (a nut, washer with tabs to fold over, and another nut) usually work alright, but there is an easier way to go. Old Ford part # E8TZ-1A124-A, new # 8C3Z1A124A $46.55 EACH is all three of those in one. It is a one piece ratcheting style locknut that all you have to do is torque down and go. It takes a 4 prong style spindle nut socket. I have them on my front 60 and rear 70 and they work great.
brider
19
07-31-2022 07:51 PM
Bigbruce
04-28-2010 04:14 PM
hickorycornerfarm
17
06-05-2007 06:46 PM
fordmanSLO
08-13-2001 02:09 AM
