Hood release weakening
I have a 2002 F-250 SD. The inside lever for the hood seems to be "weakening". In other words, it used to release the hood hook better than it does now. Now, after I pull the inside lever to release the hood, I have to then wedge my fingers b/t the hood and the top of the grill just to create a gap b/t the two so I can manually move the hood latch and open the hood. Seems like it used to pop up further and give me more of a gap to get my fingers in there and slide the hood hook.
Any ideas, thoughts, comments, suggestions? Anyone else with similar problem? Is the hood latch mechanism dipping and needs to be reset up higher? Grabbing at straws here...
Thanks all !
Daryl
Thanks all !
Daryl
Originally Posted by FortyFords
You guys need to spend more time with your wives rather than be under the hood all the time! Did I say that?
Lubrication ,first a shot of wd-40 ,then a shot of lubriplate grease or white lithium.I mean soak the whole latch mechanism.
Rich
Rich
Originally Posted by DS02F250
How is soaking the latch with WD-40 going to make it pop up higher when you pull the release lever from inside?
Daryl
Daryl
Its 2 bolts and disconnect the latch cable. this after getting the hood open!
Mark its location first.
If your truck has been in a front end accident.It might not have been adjusted correctly.
I mean its a latch it needs to be lubricated and adjusted correctly.
"Take it to a body shop" for a latch that doesn't work HUH
Rich
Rich
tip49
09-18-2021 06:46 PM
Wayne Waldrep
21
08-03-2014 05:25 PM
