Pin Stripe Removal
Using some caution and patience use a brand new razor blade. I worked at a detail shop for a while and thats how we'd always do it. Work on an end and get a good piece up and pull lightly. Take your time though. Any scratches can usually be taken out with some compound and elbow grease. Word to the wise though, make sure the pinstripes aren't painted on, I almost made that mistake once.
WHat WRESLEU said. I did detailing too and we used razors on the stripes that were old and really dried out. Hair dryer on newer stripes, about 3 inches from the surface, and you can start peeling it up. Then a rag with GOO GONE, Simple green or I have even used brake cleaner. Removes the "shine" until I wax it again though. Goo Gone works great too.
Go to a parts store that sells paint and bodywork supplies and ask for a "pinstripe remover wheel." Its like an eraser that fits on the end of a drill. It takes off the tape and adhesive at the same time. Works wonderfully. I got mine at an O'Rielly's parts store, but Autozone or another big chain of stores should at least be able to order them if they don't stock them. Hope this helps!
FORDF100SB
06-01-2015 12:18 AM
Thunderbird7480
07-07-2011 10:26 PM
