Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 12-04-2005, 01:27 AM
chrono4's Avatar
chrono4 chrono4 is offline
Garage is empty, add now
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
windows?
does a truck have to have windows in it to be legal? im thinking about ditchin as much as posiible weight wise, and windows would be quite of few pounds of weight to shed. im thinin bout dropin the tanks, interior, windows, and whatever else. anybody got any thoughts on this, and still bein road legal?
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
STGs MinionsTechnical Advisor
  #2 (permalink)
Old 12-04-2005, 06:14 AM
truckertaz's Avatar
truckertaz truckertaz is offline
truckertaz is starting off with a positive reputation.
The only windows needed is the windshield
__________________
Bill
Teamster local 421
Do not disturb.....Already disturbed
  #3 (permalink)
Old 12-04-2005, 11:43 AM
Sam_Fear's Avatar
Sam_Fear Sam_Fear is offline
Sam_Fear has a good reputation on FTE.Sam_Fear has a good reputation on FTE.
So you legally can't just wear aviator goggles? I knew a guy that did that in an old LeSabre - had vise grips for a steering wheel too..not the smartest guy. Anyhow, think about a convertible, only glass they have is the windshield. If you still wanted too keep some cold air out, you could replace the side and back glass with plexi. If it is too thin it will tend to bow with the air pressure difference and blow out though. This just doesn't seem like the time of year I'd want to have big open holes in my cab.
__________________
I'm nothing more than words on your monitor.
  #4 (permalink)
Old 12-04-2005, 12:41 PM
chrono4's Avatar
well, it was just a thought, figured that it be kinda cool to have it completly stripped to the bone, run some straight pipes, have enough room in the engine bay to sit in, and the only extra thing id have is heat, but not sure yet.
__________________
--Andrew--
Welding a 9"
  #5 (permalink)
Old 12-04-2005, 12:48 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
1967 Ford Galaxie
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
well ask yourself this (or answer it for the rest of us) whats your purpose with this truck? If it's competition only then why worry about windows, and if your gonna run straight pipes then I beleive your missing windows will be the least of the worries for the cops.
My ranger is stripped pretty much, I even took the second layer of sheet metal out of the head liner, and took the rear window out, got rid of all the radiator support, hood latch, hood bracing, and fender bracing, and built a square tube frame to hold the fenders on, and use pins to hold the hood on.
I am thinking of removing the side windows, and regulators this year too you would be suprised how much wieght that is then I will just cover the door panel with some thin sheet alum to cover up any sharp edges. I am also going to remove some of the inner bed panels, remove the front cross member, and replace with tubing. Cut another 3" of the front of the frame and about another 5 off the rear.
__________________
Rob
Learn from your parents mistakes.......... Use birth control
  #6 (permalink)
Old 12-04-2005, 12:53 PM
chrono4's Avatar
i dont think the pipes is a big problem around here, my 83 c10 is runnin true dual on 1.5 inch piping, not deep rumbly, screamin loud, never had a problem. ive got my 89 2wd, so weve been driving it, so i want to turn the 89 into somthin special. got a dana 44 straight on the way, and a 60 rear. its got roll bar, tube bumpers, flatbed, so i figure id go all the way out, and do it right. the only thing i want to do is keep it just enough to be road legal, incase i ever have to take it somewhere, muddin or whatnot, and dont have the trailer available.
__________________
--Andrew--
Welding a 9"
  #7 (permalink)
Old 12-04-2005, 12:57 PM
1967 Ford Galaxie
Well the question is do you plan on driving it in the winter that makes a heck of a difference you know.
__________________
Rob
  #8 (permalink)
Old 12-05-2005, 02:45 AM
wyldstallyn73 wyldstallyn73 is offline
wyldstallyn73 is starting off with a positive reputation.
Been my experience that how strict your local police are is the biggest factor. I do know that legally you do need a windshield, because I used to get pulled over all the time back when I would try to drive my 73 Bronco with the windshield folded down. You might get by if you even removed your doors- some of the guys in my club drive their rigs occasionally on the street without doors and seem to get away with it.
__________________
"It's not that I'm lazy,,,, It's that I just dont care."
  #9 (permalink)
Old 12-05-2005, 01:37 PM
69 and 85's Avatar
69 and 85 69 and 85 is offline
69 and 85 is starting off with a positive reputation.
Quote:
That makes me look like a safety expert. That guy sounds like he's headed for a Darwin Award!
__________________
91 Blue F250
  #10 (permalink)
Old 12-05-2005, 01:40 PM
1967 Ford Galaxie
Quote:
Hopefully before he can/could pass those gene's on into the gene pool but alas most of those types of idiots are usually pretty prolific too since they aren't smart enough to figure out what any type of birth control is.
__________________
Rob
  #11 (permalink)
Old 12-05-2005, 02:16 PM
Sam_Fear's Avatar
I thought it was legal to run without doors as long as you had proper belts. How about CJ's with no doors?
As for the vise-grip guy. I don't even remember his name, he worked as a hired hand with us one summer. I doubt he could stay out of jail long enough to procreate anyhow. I think the crow bar marks all over the car showed up about the same time the windows disapeared... we never did have the ***** to ask how it all happened.
__________________
  #12 (permalink)
Old 12-05-2005, 04:14 PM
chrono4's Avatar
i never considered the no door option. sounds like it could be fun. chop half the top, rip teh doors off, run a cage and 5 points, but its got to move first.
__________________
--Andrew--
Welding a 9"
Tags
ford, truck, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
