`05 Lariat Backup Beep
Is there a way to disable the backup beep on an `05 Lariat. Not the beeping from the sensors on the back bumper, but the beeping that happens anytime the truck is in reverse. Beeping like some big trucks have. Im sure there is a way to disable, it seems as though its sharing the alarm horn, but not for sure. Any help? Thanks
It sounds like someone added a back-up alarm, if so it is prob located somewhere on or near the back bummper. Locate the back-up alarm and disconnect it!
If you are talking about the back-up sensor in the bumper, just turn the switch off on the dash. (remember you need to turn it off ever time you start the truck.
OK let's see if I understand. When you put the truck in reverse, you hear an alarm! Did you make sure your tail gate is up, and that there is nothing in the "sensor zone" like a trailer hitch. Did you try turning off the back up sensor on the dash? Push in the button and a yellow light come's on, yellow light on = back-up sensor off! If you have done all of this, and there is still an alarm when in reverse, I still say you have an add-on back up alarm!
Galpin Ford in Van Nuys, CA (largest ford edaler in the world) adds some "ultra-guard" or something like that, after markey alarm to every vehicle, and it is an option you can't remove when you buy the car. They just won't remove it form the vehicle. It's also 400 bux...thats how they kick you!
Everyone I know with that alarm system has a back up, audible beep that is emitted whenever the car is put in reverse, in order to alert pedestrians and stuff that you're backing.
I purchased my 05 F150 Lariat from Pasadena Ford here in So Cali with just the Ford factory alarm, and I have no beeping.
Hope this helps at all
-Louie
-Louie
