Fuel filter replacement
Old 05-25-2005, 11:54 AM
neilc88's Avatar
neilc88
neilc88 is offline
I purchased a new fuel filter to replace the original. Upon inspection of the old one, I only saw one of the safety clips that help hold the fuel filter outlets to the fuel line. On other vehicles there were clips on both sides. Did Ford go cheap on only supply one clip or did a bone head at the assembly plant only give me one of two?
Note: The new Motorcraft fuel filter contains no clips.
Old 05-31-2005, 11:24 AM
neilc88's Avatar
neilc88
neilc88 is offline
Bump up, any comments?
Old 06-01-2005, 06:00 AM
smassie88's Avatar
smassie88
smassie88 is offline
When I replaced mine on my 2000, it had no outside clips. It has the inside ones that require that special tool that suppose to slide inside and release the filter. Mine had been done prior to me and one side the clip/clamp on theinside was bent really bad. Went to my local NAPA and they sold me a replacment that looked nothing like the original but infact DOES work. Ford wants you to buy the whole line for the little clamp/clip on the inside. Hoped this helps.
Old 06-01-2005, 07:05 PM
wylecoyote's Avatar
wylecoyote
wylecoyote is offline
My 2000 ex only has one clip also. Think they went cheap I guess.
Old 06-09-2005, 01:08 PM
neilc88's Avatar
neilc88
neilc88 is offline
UPDATE: I originally thought that the factory forgot to put on the second clamp until I looked at my Chiltons manual. The picture had only one clamp also. Therefore, Ford went cheap. Probably save $0.25 by eliminating one clip. It is pretty secure up there and I just reused the one clip.
Note: The current Motorcraft part # is different than the manual. Physically, they are the same. I don't have the new number handy at this time.
The combination of gas and rust proofing sure makes a nasty tar on the hands and arms. Had to use gas to get it off.
Sonicmjf
12-20-2017 04:31 PM
wraysp
06-12-2010 05:30 PM
Blowinsmoke
09-27-2009 05:18 PM
ChuckM
1999 to 2016 Super Duty
09-21-2009 09:51 PM
ledbetter
2004 - 2008 F150
04-04-2006 04:29 PM
Quick Reply: Fuel filter replacement
