stripped header bolt
i have f150 woth the 4.6 and a stripped header bolt. i was looking for any good ways to fix it. i know i can drill and tap it. i was told about a plug type kit. you screw in the plug and then you can screw in the bolt. so any info into these two fixes or any extra fixes i don't know about will be very helpful. thanks for all the shared information.
furrby
furrby
i mean the header to head. it is on the font bottom on the drivers side. my friend told me of a kit with a drill bit and a sleve. you drill it out and install sleve. the sleve is groved for the old bolt. i just did not know how well they work. i sounds alot like a drill and tip. i can use a drill and tip with a larger bolt. i am just looking for the best fix. thanks.
furrby
furrby
i fixed the stripped out header bolt. it did not fix my problem. being right at the drivers side exhaust, i started the truck. no noise. i let it warm up for about 5 or 6 mins. then i started putting a little throttle to it. the sound kicked in. i went to the exhaust and i finail could tell. the noise was comming from the intake at the filter. i changed the intake elbow a few months back and have not had any problems until now. if i have a leak at the egr, throttle body or elbow will sound like a exhaust leak? or do i have a major problem? i going to check the egr tomarrow. if that is not it. i am going to replace the elbow gasket. it that doesn't do it, then i don't know what i am going do. any help will be extremely nice. thanks again.
furrby
furrby
i tested just about everything two or three times. after about 3 hours, it seemed to be the iac or egr. i changed the iac first based on the price and how easy it was to change. i changed it and there has been no problems. i am still unsure of how it made the sound i was hearing. the one i removed looked just fine. but i am not going worry about. it works now. thanks for all the advise i have received.
furrby
furrby
T-wood
02-14-2016 11:28 AM
furrby
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
05-13-2015 10:13 AM
