are programmers worth the $?
if you plan on doing gears and tires on a 99 and newer then theyre good for changing speedo. if you have an auto you can change tranny shift points and firmness. they read codes but you can get that done at autozone for nothing. i havent had my superchips on the performance tune yet to tell wether or not it helps my mileage.
They do make a difference, but at the expense of using premium gas. Inmost cases the higher gas is evened out by the improvement in fuel economy.
Toss in the ability to read codes, adjust tire and gears ratios (on certain trucks), adjust spark advance, log and view realtime data, adjust tranny firmness, etc, makes a tuner a very valuable tool.
Originally Posted by stang3O2
Are they worth the money and which one is the best? I've heard that some will help with mpg but I've also heard that the manufactures test are the only ones that see that. What are your thoughts/experiences?
Thanks
Thanks
I would assume it would also have benefits in a truck.
Hypertech makes a dual fuel programmer. I watched a do it yourself show on Speed TV and they made 28 extra HP on a Chevy pickup using 87 octane. They also could program a more aggressive program which required 93 octane. I'm gonna buy the Hypertech with the dual fuel capability.
Plus, it reads codes! Now if it could only cook....
